Hmm. My MR2s high beams also don't work in the High position, only when you flash the lights. Freaking annoying.
Good luck.
Good luck.
So interesting thing happened. This worked for a few days and then poof, it stopped.
I finally got around to re-installing the slee headlight harness. At first I had no brights in either direction and then POOF they worked again in both directions.
Beats me.
Good luck ya'll.
gday mate
did you end up sorting this out? sorry i know it was a while back, but i just bought an 93 80 series and i am having the same issue
So I never did have another issue. I think I was fighting two different issues. I’d clean the contacts like I did above and replace the relay if that doesnt help.
I posted in this thread in 2010. It was the relays!
So glad I found this thread. Had a similar problem in my 96 FJ 80. Checked all fuses, relays and was about to disassemble the steering wheel when I decided since I am going to replace the stalk I might as well try to pull the end off. I was able to pry the end of the stalk off and cleaned those contact points and voila, problem solved, for now...well it wasnt the switch, I pulled it all apart, checked the contacts, checked continuity, all OK. I guess I'll work my way down.
