Headlight Switch
The Ghetto
Ok. I bought an additional headlight switch with my EZ Wiring harness. I attached some pics of the switch and a diagram. The switch almost matches the diagram but that top right connection on the diagram isn't parallel....it's just off on its own. Also, where do you ground the switch?
Any known ground to body is fine. You can do a quick test by hooking your test light to a nearby bolt and touching it to a hot fuse. If it lights, you got ground.
No no....Where does the switch ground at? On the schematic it states on the switch itself. Maybe it goes to one of male posts from the switch. I tried drilling into the metal on the switch and nada. I'm all f'd up.
If I understand you right, the switch will be grounded when it's screwed into the metal dash.
Yup.
In this picture of your switch, is there not a spade connector comming off the body of the switch, near the top of the pic?
In the event that this was mounted into a fiberglass bodied vehicle, it would not ground as it would in a conventional metal body configuration, hence your ground connection on the body of the switch.
attachment.php
mdjohnsen said:
Yah thats the pic of the switch. I think grouding it to the diamond plate dash I have works just fine.
As long as your diamond plate dash is mounted to something metal, or has a ground lead to it from the frame, oh and the frame is grounded properly....
All is well. Basically I had to read french when it came to directions. The splicing meant I had to run a jumper wire from the headlight spade on the switch over to another spade to enable the switch to act like a switch. All the lights were running constant. I thought I was f'd. Finally everything works fine but two things 1. The headlight switch has two clicks when pulled out as do other headlight switches. And the first click which should only be parking lights turns on my headlights and the second click is the same. 2. Again....my fuel sender gauge is acting strange. All new wires, - from the gauge to the sender to ground. It was reading what looked accurate and then it went back down to E slowly. I spray painted the top of the sender plate after all was done but I covered all the hookups well before so. Really strange. Oh, can you share grounds?
