A rock broke my pass side low beam glass lens.
I have the replacement headlight unit, but am having trouble removing the original headlight unit.
Since I have the new unit, I can see where the screws are that hold it in. The last screw I need to remove is at the bottom near where the turn signal corner lite and the low beam come together. I think I can remove it if I could remove the corner light unit.
My questions:
1. How do you remove the turn signal corner light? I removed the top screw, but not sure what to do next.
2. There is a plastic trim piece that runs below the headlights and comes up between the low beam and high beam. It appears to need to be removed before the HL unit will come out.
I have searched and found several posts but none on the 2001 LX. I do have the Repair Manuals but they do not address Headlight Removal. Could not find any pictures showing how to do the job.
Any help would be appreciated.
My questions:
