Hello all,
Just signed up and am the pround new owner of an 1996 fj80. Purchased in Cali and brought home to B.C., Canada. I am in the process of getting it ready to pass the federal inspection so I have to install DRL's (Daytime running lights).
I purchased the Hamsar 45070 pro/auto drl kit to put in. This kit is automatic, has photo sensor to turn all lights on/off at dusk/dawn, and has a delay switch to allow the lights to stay on for a certain time after key is off. It also has a second ground wire that can be hooked up to a toggle switch that disables the kit when not needed.
Headlights worked great at first but then I installed the kit today, and when finished, nothing worked (lightwise). No headlights, no parking lights, or dash lights. By disconnecting only two wires (white and yellow) I can return the system back to stock. But still, no lights. If I pull back on the headlight switch then the headlights will flash on.
I should say that an aftermarket door lock/alarm system was added by previous owner and that it has a 4 pin trailer harness on it.
Here's a breakdown of the wire hookups.
Green - connected to switched 15 amp ign fuse in fuse panel
red - thru firewall to hot always on distribution block
black (2 of them) - to ground
white - connected to red wire coming out of headlight switch on column for headlight illumination
yellow - connected to yellow wire coming out of headlight switch on column for park lights
the photo sensor and delay switch also have ground wires.
This was all wired as per Hamsar's instructions, I think. The instructions say to connect the kits white wire to a wire between the headlight switch and dimmer switch. The kits yellow wire to be connected to the park light circuit after the headlight switch.
The headlight switch has 3 wires coming out of it: red, white, yellow.
When I connect a test light to the red wire, the headlights come on (high or low beam depending on where the switch is). And when the test light touches the yellow wire the park lights come on. White wire does nothing with test light. I'm guessing that this is a ground controlled switch? I checked the fuses and bulbs and they are all fine.
Any suggestions??? My thought is that the column switch is fried. If so, must have happened during install or activation of kit. I am not very knowledgeable about wiring. Do you think I should have put the kits white and yellow wires somewhere else? Can anyone with an EWD confirm this?
