Headlight moisture...how to remove it?
Texas
Website
www.peopleschoiceins.com
My 80 has been sitting unmoved for about 5 months. Now the headlights have a bit of moisture in them. I assume it can somehow be removed.
pass side
drivers side
Any thoughts?
I got some in my headlights on a recent wash (did the engine bay also) using the headlights just made it condense on the lense, what worked was pulling all 4 bulbs out and driving arround on a hot day
The lights ain't gonna do it- the moisture will still be in the box. You need to open the box and get the moisture out. Pull the bulbs and either move air through them, or you might try alcohol plus air movement. You'd probably have to remove the assembly for that, then pour in the alcohol, swish around, and dump, then air out. I have no idea what the alcohol would do to the fixture. I'd try RavenTai's idea first, not because I think it will work (except that he said it did) but because it's easiest, and you should always start with the easiest. :D
-Spike
-Spike
Thanks. I'll try that.
What about a hair dryer on low heat and hi speed...get a lot of volume of air moving around in there...
barrypt5
