So in my ongoing 1978 FJ project I came to the tackling of my intermittent headlight issue. I knew by fiddling with the wiring harness coming up the column that there was a loose wire in the turn switch assembly. Pulled it apart and found the RY wire in the picture was not connected anywhere. The way the wired layed and marks on the terminal, I figured I soldered it back in the correct place but.... Everything worked right for a minute and then I completely lost headlights. Does anyone have a picture or can anyone tell me if did it wrong?
Several pointers: Sometimes those column switches simply wear out and need ex$pensively replaced with OEM. Other times an accumulation of dirt and grease on the contacts needs cleaned with Q-tips and a bit of solvent. A dab of grease on the large BB is good. And some time spent tracing the circuits within the unit is instructive.
Your RY (red w/yellow stripe) wire looks to be on the correct terminal (although the original is soldered on the side of the terminal). Operate the turn signal/headlight flasher arm a few times to make sure the contacts are changing their positions correctly.
You may have accidentally shorted or grounded a wire in your repairs; look carefully. Also check the 3-terminal connectors plugged into each headlight bulb for loose wiring/corrosion. And of course whenever something electrical blitzes, check your fuse panel with a flashlight to look for blown fuses or fuses of the incorrect amperage.
HTH
Thanks for the info. At least now I know that I got the wire back in the right place. My fuse is good and have power at the block. Guess I got some wire tracing to do.
