headlight fault
Northern Territory Outback Australia
Hey,
My 80 no longer has high beam. It does if I pull the headlight switch toward me but does not if I push it forward to engage high beam. Although, the blue high beam light does engage on the dash. Just a faulty selector switch?
Yah bad switch I think, I had the same thing happen last year. You'll need to pull off your steering wheel to get to the assembly with the switch. Not a hard job just be carful with the airbag. Local auto store should have a steering wheel puller for rent, I recommend you get one.
Cool, thanks man. With the airbag, what do you mean by be careful, is there a chance this could go off?
The service manual makes a big deal about it. Just be gentile and keep it facing up at all times. Just in case it does go off it wont launch at something. Im guessing its one of those safety things like the "dont take a bath with your blow drier" kind of thing...
IMG_1839.webp IMG_1837.webp anyways, just swapping out the entire switch unit is easy.
Hey,
gday mate
did you end up sorting this out? sorry i know it was a while back, but i just bought an 93 80 series and i am having the same issue
