Will faulty DLR cause the right headlight to go out?
2003 LX470. Initially, right headlight is out. When the fuse is pulled then replaced, the DLR clicks snd right headlight works. Light continues to work until vehicle is turned off. When vehicle is started, at night and headlight switch is in ON position right light is out, pull and replace fuse, DRL click's and light turns on. New relay is $140 and I don't want to replace if it isn't likely to be the issue.
Cheers!!
Cheers!!
