Headlight adjustment help!
Kirtland, OH
Ok, being a new 80 owner (yes, :flipoff2:) I have the Low Beam & High Beam headlights WAY off on my LC. It's a 1993 FZJ80.
I *THINK* the two adjustment screws (for each side) is the one that is between the headlight and the radiator support (pointing up)- the other is by where the low beam bulb itself is taken out to be replaced (pointing toward the firewall), correct?
Could someone please shed some 'light' on this for me? (Pun Intended)
Otherwise, I'm Screwed (No Pun intended!) :censor: I'm thinkin' by the searches I have done that perhaps the only option is to fully replace them?
Thanks in advance, and I already did a 80 Series Tech search and didn't find much help! Sorry! :bang:
John
Here is the procedure from a '96, IIRC they are all the same? Well other than Spike's, his is more like, shave the wood, tighten the zip-ties, etc!;p
THANK YOU THANK YOU THANK YOU THANK YOU!!!
That is EXACTLY whatI needed to identify what I was doing. Let's see if this helps adjust these - I'll report back on the outcome!
I owe ya a beer!
John
Wow. Screws. Vials. Indicators. Who'da thunk it? What, shims aren't good enough for you guys? :D
-Spike
