Header Wrap
In the Rat Hole
Ordered a header for my power-plant today.:) What are the pros and cons on a good wrap job:confused: I'm trying to cut down on floor board temps. Thanks, Fuzz
Their ain't much you can do about cooling engine combustion. I wouldn't go for the header wrap. It may be okay if you never go through mud but once you do it embeds into the wrap & rusts out your header quickly. Even hot coating the header doesn't do a whole lotta cooling. I'd install hood vents. I picked up some off Ebay from a 280Z & they work very good at keeping underhood temps low.
those vents are bad a$$
without even reading the post i said to myself, "Z" hood vents.
i've sold a many of those in my dayz :cool:
nice trick
Thanks for all the advise, I now see the disadvantage of mummy wrap.(short lived investment) So, LC I can't tell by your pic but do you have the original louvers on your hood also? Does rain water enter through the Z car vents? Seems to be a great idea tho. Thanks, Fuzz
If you wrap a header it will crack very quickly. It will void most header warranties. You dont want to trap the heat against the tube material. I suggest getting a ceramic coated header and use those bad assed vents mentioned earlier. You can put insulation blankets/shields to protect the starter and the power steering etc> if needed. Dont wrap the headers , you'll be sorry!
but would'nt the heat from the exhaust dry them out? REALLY
nope. i had a brand new set of headers rip in half in a mild mud incident (see if you can spot the 36inch ground hawgs ;) )...turned out the new chrome headers were completely rusted through where the four pipes come together. pulled the tape off and the entire header was complete rusty crap.
that said, i am running small chunks on my headers now, but only by the plug wires and because the headers were cheap and im too poor for ceramic coated headers
Damn! nuclear, that's some mild mud incident you got there.Looks to be quick-sand?:eek: Whats up with the rear section of the roll bar ?:confused: So you think the extra mud insulation in some areas caused hot spots leading to failure?:crybaby: Is ceramic coating a plus? Damn too many questions! Better stop here.:beer: Thanks, Fuzz
I am glad somebody asked this question. I have been considering a header rap for soime time. My headers seem to generate and exceptional amount of heat. I have the Spectre 2-piece, I have had them for about 10 years now and they are rusty and ugly but do not seem to be leaking (might be though). It just seems that there is a lot more heat these days.
the rear of the cage was one of the dealer installed baja cages that mount farther back and higher than stock, so my softtop wouldnt fit. cut it off and eventually welded in an angled bar.
ceramic is the way to go, just make sure they coat inside also. some only do the outside, so the header rusts from the inside out.
Yes, the factory vents are still there. Try & get some that have the rain catch. I'm not using them cuz my factory cannister inlet is well in front of the vents. If I was using my old K & N filter, I'd use them:
