Header Flange
Honolulu, HI
Hi guys,
I'm almost to the point of getting the tub back on my build, but realized it'd probably be easier if I got the exhaust all done beforehand.
When taking the truck apart, I threw away the exhaust from the header flange back, and now am trying to figure out how I'm going to do the new exhaust. I'm really tight on money, so buying a system is pretty much out of the question. I have a new 40 series flowmaster muffler, so all I need is the piping. Should I a:finish the build, then drive it to the exhaust shop for them to bend pipes with my muffler, or b:build my own system out of the random exhaust pipe pieces you can find at checker. Would that pieced together version last? A problem with that idea though is how can I bolt up to the header flange.
Any ideas on what route I should take?
Here's a link to something i found online that might work to bolt to the flange:
HEADER REDUCER KITS - JCWhitney Auto Parts
And here's a pic of the header I'm using. Thanks for any suggestions!
-Mike
Do you use the ball version? I was looking at a header adaptor mated to this to allow for flex in the system?
mikedickbek
Your engine is looking great!
The link leads to:
Hedman #500-21107
3-Bolt Flange Style Header Reducers
Pre-Welded O2 Sensor Fittings
3'' Diameter Collector
2-1/4'' Diameter Outlet
2/pkg
The braided coupler is a nice idea, but not necessary in a Cruiser w/ 4 almost solid motor mounts.
I pieced together a system for my Pathfinder from auto store parts. That was 4 years ago. It still works fine though it's rusted badly. If you plan on replacing it in a couple of years I say go for it.
