Header bolt discontinued?
San Antonio, TX
So I picked up an fj62 a few months ago and have been putting some work into it. It had a nasty header lesk when I first picked it up and replaced the o2 sensor gaskets since they literally had red rtv as a gasket.
So i've been told it's a man-a-fre header but it's missing two bolts on the bottom. It takes 4 studs and nuts, 8 like bolts and 2 oddball bolts pn#90119-12069. I called a couple dealers and was told they were discontinued, and an internet search came up with the same. Is there a source for these bolts or does anyone happen to know the size? Any help would be greatly appreciated. Thanks!
As you can see from the pic there is a tab welded onto the lower flange and that's how the header flange winds up being the same thickness as the intake flange. That bolt where the arrow ponts to is where the missing bolt is. There is one more bolt just like it on the other end of the header thats missing as well. Again any help would be appreciated. Thanks!
http://s846.photobucket.com/user/jcarrillo210/media/headerbolt_zpsa3661e6f.jpg.html
no dice? No one has a lead on where to pick them up at or what their size is? I took out one of the other header bolts from the very end and it's way smaller than the bolt's that I'm missing.
An 8.8 is fine in that application and the repeated heating and cooling cycles will eventually anneal a 10.9 to be an 8.8 or less anyway. Plus, 8.8's are far easier to find.
Well if anyone else ever has this problem and does a search hopefully they'll find this thread. pn#90119-12069 is in fact discontinued by Toyota so if you lose or break the bolt they can't help you. I went out and bought M10 and M12 bolts and one was too small and one was to large. It's in fact an M11 bolt which no one has. I did some more research and read that a fine pitch 7/16" bolt would fit so I tried it and can confirm it fits like it was meant to be there all along. a 1 1/2" long 7/16" fine thread bolt will work for those two odd ball bolts that you can't get from the dealer any longer.
This was very helpful as i just ran into this swapping my manifold gasket and found 2 bolts were missing the whole time. I will look into this! Thank you
