Hi All,
Was wondering what the torque was for the head of a 77 2f on the bolts. Also is there a pattern that should be adhered to for the proper pressure to be applied such as a tire pattern when you change tires so they do not wobble.
Secondly, I have a 2f (same as above) that has a distributor that may need to be replaced. I have taken the cap and rotor off and they were slightly corroded. If this was your cruiser that you planned to have forever, what whould you put on it? for the record I am real shakky on the terms I have read here in regards to electronic, DUI, (i think) PEI, etc. So if you can please explain.
This is coming after a rebuild that was professionally done and it ran great until the end of the summer about (2500 miles) but now having some warm weather backfiring. runs good cold but when warm it loses all power and backfires and you are almost unable to move until you get the rpms up to 2500 3000 to let out clutch to get home. When I last ran it 25 degrees out and it was great. after warm it did not back fire after an extended run too. just trying to fiqure this out. I have replaced, plugs, all cap wires to plugs and ignition. I also dropped to oil and let it sit to see if there was any film or shine to the top in case if major internal damage (antifreeze leak). none so want to eliminate all variable before it has to back in unter the knife.
