Head lights just quit working
Knoxville
So I just went out and started up the 80 and both the headlights are not working. Parking lights work, both brights work, but both dims do not. Bulbs are good. Fuses at the main box are good. I do have the Slee wiring harness. Any thoughts on what it could be?
Check the ground and then the connectors. I had the same issue and my driver side low beam had burned out at the connector between the new and stock harness. Have since disconnected the Slee harness but stock bulb connector is toast so about to parts one out and replace it.
Ground wire?. seems like I had that issue years ago and there is a single ground or connection for both, if dead then both die.
It looks like I've blown one of the 30A fuses that is part of the Slee harness. Been a lot of rain here the last two days and there was some water that got in that fuse (my fault, I must not have attached it back to the body panel last time I unhooked the battery). Swapped out fuses with the brights and dims work now. Anyone know if these fuses are readily available?
That's a relay. Hit your local auto supply. Mine went out too, though not sure why. Not a lot of water in Southern California.
