Hi all, I need so help asap, my fzj80 just failed its MOT test on a headlight problem.
you have both headlights on, on normal low beam, and as soon as you put the high beam on, the right handside (as you look from front of car) headlight goes out with no low beam or high beam lights working on that side, but the left handside both high and low beams are lit up, as soon as you take it off of high beam, then both the low beams work,
I hope I have explained it ok.
The reason I need to get this sorted, is because the MOT testing place will charge me another £40 for a retest, so have 24 hours to get the problem sorted....hope you can help!
PS I have taken off all the bulb connections and can't find anything wronge
