Head light keeps burning out
I have had my 97 cruiser for about nine months. I now have to change the passenger head light for the third time. I bought the cruiser in December and installed a set of silver stars right away and know the passenger head light has burned out for the second time. My lights are always on when I am driving the car so they get a far amount of use a lot more then if I just turned them on at night. Do I have a wiring issue some where? Would Slee’s harness help me with this? This just seems a bit excessive to me. Thank for your input.
Mark
I would definately make sure you are not touching the bulb at any time (the oils from your skin will cause heat build-up and premature failure).
That aside, I certainly think the Slee harness is a great upgrade for all the reasons mentioned on this site (just do a search). You can also check out Daniel Stern Lighting for more detailed info.
Given the inexpensive price (relative to other cruiser mods) I can't say enough great things about an upgraded wiring harness. You can even do it yourself with the info from Daniel Stern, but I went with the Slee product b/c it was fast and I knew the quality would be excellent.
I have not touched the bulb when installing. It is possible that the bulb has touched the side of the housing when I have been installing it. Could this cause the same problem.
Thanks
Mark
Quit installing the POS silverstars. They have a history of not lasting. Google "Silverstar burn out" and you'll see. Then read the lighting FAQ in the 80's section for details on HIR bulbs. These bulbs will last, and also give you better lighting.
X2.
Thanks for the help. I have been running silverstars in my cars for a few years know and this is the first time I have had a problem. I will look into the HIR bulb option and upgrade the wiring.
Thank you
Mark
I had the same experience with silver stars. I stopped using them after purchasing 2 full sets in less than 1 year.
I had something similar , but ...
A crack in the plastic lens can let moisture in and cause a problem as well, although I had 1/2 inch of water in mine from an ill advised pond crossing for about a year without burning out the bulbs.
Not from a pond crossing, that's for sure ! :grinpimp:
After buying the 3rd Sylvania bulb I decided it was time to get a shop vac & get the water out.
The last bulb went 'preggo' - I asked the guy at the parts store if he had ever seen that happen before as I did not touch the bulb(s) - his replay was that yep, it's caused by moisture. :flipoff2:
So far, so good although the inside of the P.S. lens is still slightly green at the waterline. :lol:
Britt
