Head light indicator light.
Dover, DE
I have not dug into this yet but I did search for a similar issue.
Occassionally, my high beam indicator light (blue) will light then go out after a minute or two. This usually occurs when it is cold outside. (20's for East Coast 😁).
After a few minutes it will work just fine. When the light goes out. If I go back to Low then to High then it will come back on. If I "flash to pass" it will work fine. Once driving for 15 minutes or so, it works fine.
I would assume the power for the indictor comes on with the power through the switch for high beam.
Dirty contacts in the switch or some other issue?
