Head light aiming PITA
MA
My left headlight has been way too high for quite a while. I think the only reason I didn't get brights flashed at me too much was because it was aimed above most drivers.
Of course, the plastic gearbox adjuster was seized up. (Does anyone know if that is an orderable part). I had to take off the grill and the transmission cooler to get at all the screws holding the headlight on and almost took off the bumper. I got the headlight aimed, but in the process busted off one of the bolts holding on the trans cooler and broke a plastic clip holding on the body panel under the headlights. (the joy of a rusty landcruiser.:frown:) In any case, it ended up taking an hour and a half to do and I did it a night so I could aim the headlight.
Bottom line: Head light aiming = :banana::banana:+ if the adjuster is broken. Total PITA. Just thought I'd share.
yeah taking the head light off is a pain. i had trouble too but didnt break anything. how about using rust penetrant. maybe that might loosen the adjusting screw. rust always makes a easy job :banana::banana:'s
:cheers:
I am going to try to find something to soak it in that might loosen it up. Are the gears in their metal or plastic? I've heard that they are plastic. A concerning thing about mine is that turning the part that turns the headlight adjuster on the back of the headlight housing turns the adjusting screw, but turning the adjusting screw does nothing.
They are plastic and aren't replaceable by themselves though Toyota. I've seriously thought about rebuilding them with metal gears, but am still not sure where to source them. Stupid little plastic gears. :mad:
