So the cruiser started to run warm tHe other day after never previously getting above the half way mark on the temp gauge ever since a rework of the cooling system (new water pump, champion radiator, hoses, thermostat, etc).
I have not been loosing fluid and the last oil change had no evidence of any foreign substances according to my visual and the lab test.
When it does heat up it gets to about the 3/4 mark after running without issue for a good 20-30 minutes. It starts and runs fine with no white smoke or rough idle which to me seems like a pinhole somewhere that is bleeding off pressure. Pressure tested the cooling system and it slid from 15 to 10 psi within a half hour, but had an ill fitting cap so that test wasn't very conclusive.
Did a compression test yesterday
1. 130 psi
2. 130
3. 125
4. 100
5. 120
6. 125
So, is cyl #4 the culprit and is it the start of head gasket issues or is there something else worth testing or trying first?
Ian
1. 130 psi
2. 130
3. 125
4. 100
5. 120
6. 125
Ian
