Time to do the head gasket...my question is should I send the head to a machine shop and get decked and a valve job? Truck has 180k on the odo meter and has been trouble free since I have had it. To my knowledge, it has never over heated and has been a reliable truck to the PO. I got a gasket kit from dealership (got a good deal) and will get into it in a couple of weeks as time will allow. Any and all comments are welcomed. Thanks in advance.
Are you doing this as PM? If it blew, I would have the head decked at the very least, and if you have the $$$, go for the valve job. If it hasn't blown, I wouldn't worry about it. If it doesn't use oil, I wouldn't put a priority on the valve job. Make sure to post pics of the process and your original HG.
Sorry, should have stated on the orignal post. Using and losing coolant and have found in the last week water in the oil...milky white on the dip stick and under the oil fill cap. In the last few months I started to notice the temp was a little higher than normal...checked coolant and was low. Thought it was kinda strange so I kept and eye on the fluid levels from there on out. Truck has temp guage conversion, so it moves a little quicker than stock. That is when I first noticed(a few months back) that the coolant level was low. Now, in the last week or so, I have found the water in the oil...damn.
Well, I got the gasket kit coming and I will do the install on the weekend of the 16th and 17th. I take some pics of the work and the bad gasket when its out. I kinda lean to getting the head decked at least not real worried about getting the valves done but...while it off...dunno comments, questons, suggestions?
I'd call Cdan for any parts the standard dealership valve grind kit does not include (several). As for the head work, from your mods and other trucks I'd guess you're going to be a heavy user that's more demanding on the truck so I'd have the head checked by a pro for flatness, the valves adjusted and new Toyota valve guide seals put in. That way you KNOW you're good to go even while pulling a buddy's broken rig up a hill on a hot day. No question, done deal. Don't spend the money on getting the head decked until you get the machine shop's flatness info as it may not need it. I'd sooner spend the $ on getting the injectors cleaned and calibrated while they're out, which may get you both more power than decking and better fuel economy to pay for itself in a couple year's driving.
As the PO of that truck I can say that it never overheated in the four years I owned her. Sorry to hear about that Tommy. I'll check with the and see if the time is available to give you a hand.
