Right. So, I have a few questions that are probably plainly obvious to many of you, but having never been in this situation before, and not finding what I'm looking for in search - I figured I'd ask.
Background: yesterday my head gasket finally failed (I guess it had started earlier, but it's official now. No overheating at all. A few days ago I started loosing cabin heat. Checked the coolant level to find it was low. Topped it up hoping it had just slowly gone down over time. Was good for a day, then patchy heat again. Again, checked coolant level and it was low. Filled it up again, and this time my overflow bottle was full (previous time it was not). I had a hopeful thought that the rad cap was allowing the system to push coolant out, but not letting it back in as it cooled. Friday on my way home from work, I stopped at a parts store about 3 minutes from work. Grabbed a rad cap and swapped it out in the parking lot. Re-started the truck and got the white smoke show. F$&k. Guess it wasn't the cap. Drove home (no overheating at all) and parked it in the shop. (No white smoke while driving either)
1) knowing this, coolant is obviously getting into the cylinder when I shut the truck off. Tomorrow I would like to move the truck outside to pressure wash the engine bay, to make it a little nicer to work in there. I assume I should pull the spark plugs and spin it over to get the coolant out before I try to fire it up... (So I don't bend the connecting rod)
2) how long can it safely sit with a little coolant in a cylinder? I hadn't planned on tearing it apart for a while, but don't want to end up damaging the cylinder walls... What is the best procedure here?
3) I see everyone saying order the kit from CDan.... But he's not selling parts anymore. What's the best option now? Does anyone have the part numbers for the "missing parts" that he added to his kit over and above the standard valve grind kit?
4) My local dealership can order parts, and I am understanding that it's not worth cheaping out and going non OEM on the HG, does that go for all the other bits too?
Thanks!
Thanks!
