head gasket plus more...
north vancouver
hey guys..
I am well into my head gasket...(ARRRRGGGGG wirring harness PITA)
I am at 230k miles. now that i have everything ripped apart, it seams like a good time to do the rest of it, the lower end.
what do you guys think? should i pull the entire engine and do the rings and bearings now or is that not needed with these engines. the truck runs great, aside from the resent head gasket failure,
thoughts?
thanks.
scott.
I wouldn't pull the engine. It was running great so replace the HG, have the head cleaned, clean the carbon off of everything, replace the valve stem seals, get a valve job if needed, have the head pressure tested, clean the injectors (if needed), use new OEM parts and reinstall.
-B-
-B-
what he said :D
agreed, it seems to be strong (unlike the dang HG), but isn't there some easy way to really find out (i.e. quantify) how "good" the lower end is?
like taking a measurement on one of the main bearings, or wiggling the crankshaft just the right way or something...
or is it just too much work to drop the pan etc to bother?
Trust me, don't pull that engine, you're looking a 20+ hours to R&R that engine and that's if you know what you're doing.
Good luck!
