There's some oil residue around the engine block. Was told the headgasket is slowly leaking. I'm not much of a mechanic, and don't know how to replace it so is there a quick fix or oil additive that will reduce the leak? What's the most cost effective way of fixing this issue? Mileage is 135k.
You sure it's the head gasket and not the valve cover. Former is expensive, later not so bad by comparison. Unless you do the work yourself, the HG including machining the head will run you anywhere from $2000 to $2500 for a shop to do it.
I think general consensus on the board is to try and clean up the existing oil on the block and then watch for where it leaks out. It should give you a much better idea of whats leaking. No need to jump to the HG yet. There are number of somewhat common places for oil to leak out. HG is possible, but not nearly as common as Valve Cover seal, Dizzy seal, oil pump cover, etc.
X3 on the valve cover. Clean things up, then keep an eye on it.
I just recently worked on an 80 that the regular mechanic informed the owner that the engine was shot due to "all" of the oil leaks and due for a rebuild. The valve cover was extremely loose, you could wiggle it around loose, and the bolts were backed out.
I replaced the gasket and tube seals and not a single drop of oil has been seen since! Maybe I should have charged him the $4,000 the shop was going to charge for the rebuild
Alright folks, going to clean up the engine & then check for leaks. BTW, how much would a valve cover gasket change cost? How much for just the gasket? I'll check with CDan when he comes back but would like an estimate for the fix.
Depends on if you are going to do the work yourself. The job is easy, and will take you a couple of hours and about $60 in parts if you replace the spark plug tube seals while you're in there.
Having a shop do it will run you several hundred dollars I would imagine.
It is almost surely the valve cover gasket and since you have a 3fe it is very simple and should be about 15 bucks. I would do a valve adjustment and clean the throttle body while you are at it.
If you list the year of your truck in your signature it will keep help people know what advice to give.
