Head gasket going bad?
Wherever the money is!
image.webp image.webp image.webp I've got a 94 80 with 161000 on it and I've started to notice oil or coolant on the front end of the motor. I know the dizzy o ring is bad but would that cause oil to leak around to the passenger side of motor? I'm hoping this isn't the HG going bad but it looks that way as the front head bolts are wet. Haven't noticed any loss of coolant or oil but something is leaking somewhere.
Any help is appreciated as the members on here know WAY more than my local dealership
It's also possible that your belts are slinging some of that oil around from a front oil pump seal, front main seal, and the dizzy o-ring. My dizzy dribbled oil on the belts, caused my belts to fail under critical WOT condition, caused a hot, high pressure spike in the cooling system, and blew up my radiator. I also had the crappy aftermarket belts on it like you have. Don't get me wrong, Gates and Goodyear make some good belts, but anything that is cogged on the back side needs to be changed out on these and it will be a bit more reliable and it will be quieter.
Due to my severe failure, I changed my VC gasket, Spark plug tube seals, PCV gasket, Dizzy O-Ring, Oil pump seal, front main seal, all my front hoses, and I am 98% leak free.
Oh.... and what I see here has absolutely nothing to do with a head gasket failing. A HG failure rarely fails to the OUTSIDE. Only if you see WHITE smoke (a lot of it) experience continual loss of coolant, or severe overheating. Looking under your 710 cap means nothing.
Thanks for the help guys. I feel a bit better now knowing it's probably not the HG as the coolant is good and my digital gauge has never read above 190 and never smoked. Any tips on doing the VC gasket? Anything else I should do at the same time?
Do all the coolant hoses by the firewall including PHH down below and all hoses under truck leading to the rear heater.
Wrap the wiring harness by the EGR
Dizzy O Ring
Belts
PS Hoses
Oil Pump Seal
Front Main Seal
PCV Valve and Seal
Spark Plug Tube Seals
VC gasket (Look for correct torque values when re-torquing. I think the FSM is wrong (too high)) Don't strip out your VC bolts in the head. The ones behind # 6 are hard to get to.
Spark Plugs
Cap
Rotor
Wires
Toyota Red anti-freeze
Coolant Flush
As many vacuum hoses as you can find
Throttle Body Gasket
vacuum hoses under throttle body
Intake tube if it's questionable
Ok great, thanks again. What do you mean when you say wrap the harness by the egr?
I also noticed after driving around for a bit the front of my motor is bone dry and doesn't look as if there's a leak anywhere. Is that any indication of where the leak is? The pics were taken this morning after sitting all night
The trucks with the 1FZ-FE (Yours is a 94 and has this engine) has a wiring harness back behind the VC by the EGR. The 95-97 are more prone to this, but the EGR valve cooks the wiring harness and will melt wires in it over time, causing all sorts of electrical problems. Wrap it in heat reflective tape and pull it away from the EGR as much as you can without causing more problems. Do a search for EGR Harness.
From the pics I see at post #1, the front of your engine is not bone dry. Maybe the leak blew back on the engine before it dripped off, but in the first pics, the VC is leaking , the dizzy, the PS hoses, and possibly the oil cooler of the right side of your engine.
Whatever you do, when removing the intake tube, do NOT remove the screws in the AFM between the intake tube and the air cleaner. You will cost yourself $500 to learn what that means. If you don't know what that is, do a search for 94 AFM and you'll find it.
Search is your friend.
Good luck!
Ok cool, I'll search a few things and get some parts ordered.
I know the pics show the engine pretty wet but, like I said after I took the pics I drove to town and looked again when I got home and the motor looked almost totally dry.
Thanks again for the help
@cruiserdan (CDan) can get you what you need in parts. He took great care of me. If you call him or send him a PM with what you want to do and tell him "and I want to do all the "while I'm in there" things", he can hook you up with the right stuff!
