head gasket final notes
Atlanta, Ga
Well I've given it about a week to make sure nothing was wrong, but now I feel comfortable saying my head gasket job is done and I'm really happy about it. My total list of parts included the dvd and the list of parts that accompanies it, new fan clutch, starter contacts & plunger, fan clutch, toyota red coolant, 3 radiator hoses, both pcv hoses, silicone heater hoses, air filter, and sent fuel injectors to rc engineering. I should have done a better job collecting all the parts before I started but I ended up going to my local toyota dealership about 5 times (at least the parts guy was cool).
I am also really pleased with the job that rc engineering did. The turn around was great and the printout they send you when you get the injectors back was really interesting to see; my injectors were struggling pretty badly when I sent them out.
Starting out I was really surprised that a lot of the valve cover bolts could be taken out totally by hand. That's just something that I've noticed people mention in the past. I wonder how these bolts in particular get so loose.
My most annoying episode of this whole thing though was when I had everything buttoned back up and gas started spraying out from one of the injectors. After taking it all back apart it was obvious when I had put the injector on the fuel rail the little o-ring had been sorta smushed and not gone in right so I just replaced it and no problems.
Oh and that manifold stay that bolts to the block and to the intake manifold really sucks. That bottom bolt is extremely awkwardly placed. As it suggests in the dvd, just bend it back and don't unbolt the bottom bolt...I made that mistake.
I'm also really glad that I switched over to red coolant. I ran water for a day and drained the block and radiator a few times then I took it and had the cooling system flushed the next day and refilled with toyota red coolant.
Also my idle is now a lot smoother than before and I was glad to find out how easy the throttle cable and other cables are to adjust. Those things were rough to get back on and I actually ended up unbolting the throttle body and attaching them with it unbolted and that made it extremely easy.
I still need to go on a longer trip to see how it holds up. My issue was the fluid bubbling over when I would drive back from school. Hope that doesn't happen anymore. I'm also hoping I my get a little better mileage now but I'm not really expecting anything great here.
The fsm and Doug's dvd were invaluable. I had then on the table behind me the whole time. Those ratchet wrenches as others have said were great as well. I also ended up using my 1/4 inch drive socket set more than anything because of all the tight spaces. I also loved having some air tools to break bolts loose. They made life a lot easier. Another tool that I used a lot was my new torque wrench that I used the hg job as an excuse to buy a new one.
I think my next step in the future will be to add an auxiliary fan.
This really didn't end up being a tough job at all. My only auto work experience before this had been putting a lift on an old Tahoe of mine. Just checking the fsm and not rushing make things so much easier. Also keeping tools and bolts organized throughout working made the whole thing a lot less stressful.
Now that I've said all this something will probably overheat tomorrow, but so far I'm really happy to have a new fancy head gasket along with the other items in the cruiser now.
That is pretty inspirational! :cheers:
What would you consider yourself on the 'ole :banana: scale? Tackling a HG job is pretty impressive.
Well I enjoyed reading what you had put down, I am dreading doing the head gasket on mine, but I guess I will have to do it one day.
I did a head gasket on my old Toyota surf diesel, what a nightmare of a job that was, so many items that were a cow son to get too, but I done it ok and it still runs to this day with no probs.
Keep us all informed on how it runs from now on.
I have a few issues on my 80fzj at the moment that I still have to do.
1... slight play in the steering wheel.
2... A complete new exhaust soon, my down pipe has a few repairs already.
3... change rear shock absorber, I noticed mine has lost all the oil and is a little bouncy now :-(
Has anyone got any good pointers on the jobs I have to get done, any info is always good to hear....
Regards Mick.
Great write up and great timing. I believe I've come to the conclusion last night my HG is gone on #6. I called American T, and they gave me a quote of $3,500 with head milled, without any other complications. When I told him I was a mudder, he said he'd give me a good discount on parts and labor, but still, I'm looking at $2-3,000.
I only have a driveway (no carport) and a small Craftsman set, and I don't know if I'm gonna regret taking it on myself. I have some business in Colorado Springs early next month, and am pondering getting Slee to do it for me.
At any rate, I'm sure you're proud of yourself, and rightfully so! Congrats!
-Eddie
