Head & Engine cleaning solvents?
Winnetka, IL
I have my engine mostly dismantled - at least as far as I am going to go. By this I mean, I am not doing the lower end, not touching the pistons, crank shaft, etc.
I have measured the head & block with a straight edge and feeler gauge, and both are well within spec. So my question is what is safe to use on cleaning the combustion chambers and the like? I have read brake cleaner from searching. Is this the best? Some where I saw mention of Hydrochloric Acid? Not exactly a route that sounds safe. What do the machine shops "dip" them in? I do have access to a large parts cleaner - at least for the head, not the block. I also saw that the Toyota FSM shows a wire brush on a drill cleaning the valves.
Any suggestions would be great.
Lee
If you are tearing into it this far, you might as well have a valve job done. In that case, the machine shop will hot tank the parts for you. You might also consider doing a DIY port and polish job. There is a kit made by Standard Abrasives that has all fo the stuf fyou need. You just supply your own die grinder.
I had the heads on my 3.0 V6 hot tanked, torn down, and bead blasted. I did the port and polish job on those. Not too hard, just time consuming.
As for getting rid of gunk on the engine, etc, I use Gunk® Engine Brite, wire bottle brushes, and LOTS of elbow grease.
