In terms of EGTs, it doesn't really make a difference what diesel engine you're talking about, the common belief is that about 1250 degrees F is the maximum safe exhaust temperature measured pre-turbo. You can exceed this in short bursts but generally you should avoid sustained running at a higher exhaust temp.
Installing the pyrometer probe in the exhaust downpipe after the turbo is also acceptable but it adds more uncertainty because you don't really know the exact temperature of the air entering your turbo. Most sources suggest that it will read about 200F lower than a pre-turbo probe under the same circumstances, although I have read as high as 500F. For that reason alone I chose to install mine pre-turbo. Search the internet and you'll find lots of tips for installation pre-turbo without removing the turbo+manifold from the engine.
The 1HD-T has the ability to generate very high EGTs in a very short time, even with the injector pump at factory settings. That said, most people seem to mess around with their fuel settings so you never really know what's been done. The EGTs are the only sure way to monitor what's happening.
Since adding my liquid-air intercooler I notice that my EGTs increase a bit slower but I also run about 100-200F cooler that I used to up hills that I drive often. I still haven't had the chance to run it hard up long mountain hills where I used to have to back off because I was getting up in the 1300-1400 range.
Going to a 3" exhaust will also help get that hot air out faster and is supposed to make up to a 200F difference in certain circumstances. I'll find out in a few weeks...I hate exhaust work...
