hdj81 not starting
FRASER VALLEY,BC
Hi all, I bought a hdj81 last year and love it. I had no problems with it until recently. A few months ago I was laid off and my insurance expired, so I haven't been running it. When I got hired on again, It wouldn't start. I figured the batteries were dead, and they were, so I hooked up a trickle charger. It took a LONG time to charge them up. So it started, but it was turning over very slowly. I drove it last week probably a total of 2 hours. Now today after sitting for a few days it tried to turn over 2 or 3 times then nothing. I've hooked it back up to the charger and am hoping they will stay charged and the truck will start normally, but am not holding my breath. I'll need it for work later in the week. Any input will be greatly appreciated.
i would try new batteries and then go from there.
cheers
i think you might need to charge the batteries for quite some time. I've trickle charged my motorcycle batteries, but i do that all winter and it keeps the battery in constant load mode, however on my truck when i hadn't used it for about 3 weeks, the batteries were dead. i trickle charged them for the first while to warm them up (winter) and to put a load on them, and after about 3 days i juiced it up and did a full load charge and it took about 24straight hours to get both batteries up to full.
If this doesn't do it, i would look at replacing your batteries, and if things are still a little off, you might look at your alternator to see if it is charging in the first place.
another suggestion - canadian tire or auto value, really any car parts place has a little plug into the cig. lighter type device.
when you plug it in and start the truck, it has led's to show fault codes; ie battery, alt, etc. give that a go and it should give you the direction needed.
Cheers
cheers
THis is a great place to start!
What a unique colour on a JDM 80 (avatar pic).
Brad
update: my uncle came down and jumped it. he tested the batteries and they are charging properly when the engine is running. Its weird because I was using it last week and after only a few days it wont start. Could be an electrical drain somwhere. Any other input?
89
So your uncle checked the alternator for charging, but you might want to have the batteries tested, which means isolating them and using an electronic tester....they are pricy, so you will want to find a shop that has one, midtronics makes a good one. Are the batteries matched? Very important in a dual battery system.
FWIW
Gord
Are the batts origonal japs? probably are .....GET RID OF THEM probably have a dead short in one, this will drain the life out of the other (if its any good) and make your alternator work double time. If you dont want to shell out 300bux and "hope for the best" then take both batts out of the truck, charge them with a proper smart charger separately and have them load tested. Canadian tire or any auto shop will load test for free. From there you will know where to go.
They are original matching jap batteries. they look pretty new. They're Idemitsu - Super DIEHARD "the most powerful battery in japan"
Will Canadian tire charge them and load test them? How much?
Right now im charging them separately with a trickle charger, I disconnected the negative terminals on both of them. Thanks for the help.
I guess the point I was trying to make was that 'load testing' batteries is old technology....with these new electronic testers, thay are much more accurate, and you dont have to have a fully charged battery to test them as you do for load testing. The electronic testers actually measure the area of the plates, so you know how much they are sulfated.
For myself, Canadian tire would be the last place I would go, but Im not sure what choices you have in your area.
Gord
so I took them into canadian tire, and both batteries are garbage. I need to pick up new ones tonight. what do you guys recommend? (amps, brands etc.). I did a search but couldnt find the info. Im in maple ridge, and I need my truck for work in the morning. thanks.
I have two yellow tops that i bought at costco and they have been good. I would look for the most cold cranking amp and get two of those. I think that everyone will have pro and con about different batteries so pick something and go with it.
cheers
Group 27 Interstate Workaholic is my go to battery. Fits perfectly and uses every inch of Landcruiser battery tray and perfect fit for stock clamp/ hardware.
Whatever you buy, make sure you get em with the posts offset to one side and get one of each polarity orientation so that your stock HDJ81 cables/clamps work and don't have to be extended or stretched.
Regarding cold cranking amps..
Was explained by the battery shop we deal with (Battery Exchange) that in order to achieve
the really high CCA the lead plates must be made thinner and more of em... for more surface area.
So the ultra high CCAs generally come at a cost to the life of the battery, especially in off road apps where they are exposed to a lot of vibration etc.
Bear in mind that with your 24 volt starting system you pull half the amps anyway..
Ultra high CCA would be more benefitial if you were starting the same motor with a single battery and 12v starter
Obviously the Optima/ Odyssey etc are constructed differently and the plate thing does not apply.
My own experience with Optima has not been that great. Others love em.
I did end up finding another thread (search: hdj81 battery amps). So I went to costco and got a couple of marine starting batteries for $100 each. Hopefully they last me. It was a little hectic because I needed my truck for work tomorrow. Also, I bought two identical ones, so the passenger side terminals wouldn't reach. I bought a longer one for the negative side and bolted the old negative one to the original positive one, and electric taped the hell out of it. Thanks for all the help.
