HDJ80 Headlight adjustment.
Australia
Hey, I have 1990 HDJ80 80 series cruiser.
I went out for dinner last night and noticed my high beams were facing up and into eachother. Low beams were fine.
Is there adjustments screws or would it be the bulbs falling out of place?
Any pictures or a detailed step by step guide would be highly appreciated.
They're halogen bulbs, not led.
If you have the 4 x individual headlights (2 low beam / 2 high beam) there are 2 adjustment screws for each, one up/down & one left / right for each light.
adjustment screws are accessed from the front of vehicle and should be easily seen from the outside & adjusted with a #2 phillips screwdriver
note that an incorrectly installed globe will throw out the beam pattern as well so may pay to check they are installed correctly
This is my set up in Australia
yep, those are the adjustment screws behind the cutouts in the headlight trims
top ones are up/down on both headlamps
high beam light inner screw is L/R
low beam light outer screw is L/R
