hd alternator
slc area
where do I find the cheapest alternator for my sbc that's running the taurus fan. Is 90 amps plus plenty??
84 Buick century, with AC/rear deforst, etc.
Should be 94 amps out of the box...
You should be more than fine with that.
The Taurus fan only pulls huge amps at start up...
Good luck!
-Steve
Only at startup???
I notice that the ammeter is above 30 the whole time that the fan is on, obviously you all are the pros but what am I missing??
boekppl said:
Only at startup???
no 'pro' here....
Do you have a Fluke meter wit an inductive amp clamp? If so, put it on the leads from the fan and report back.
Who is to say that your ammeter is DEADLY ACCURATE? ;)
I don't think it's deadly accurate, it's just what I observe when it turns on. Fan then turns off and the ammeter SLOWLY works it's way down to 0, is that normal?? I know only the most basic stuff with wiring and electrical.
hey poser do you think the alternator out of junkyard or a reman would be better? The reman is $100, junkyard i imagine is $25-$30. Worth paying the extra??
I have ran wrecking yard stuff for years with no issues...
Further, anything that might give you issues, Regulator, diode trio, brushes, etc. are all available from NAPA/Carquest, and you can repair it in less than an hour.
Good luck!
-Steve
Thanks poser, I'll pick it up Monday at the yard. Appreciate the help.
also check for 84 camaro, they are also 94 to 105 amp. also check to see if its a 10si or 12si GM alternator, the 12si has bigger bearings and better diodes etc. check out www.alternatorparts.com they have a lot of info and sell parts and rebuild kits and complete units up to like 240 amps. good luck!
thanks gunman, more options always better.
