Greetings.
2003 LC. During a heavy rain the hazard lights started flashing. They stopped when the car was started. I pulled the fuse which of course disabled them and also the turn signals.
I put the fuse back in 12 hours later and the flashers did not start up again and the turn signals worked. I started the car, tested the flashers (working) and turned the car off. Flashers resumed again. Pulled off the vent trim, nothing obvious in the area of the hazard switch.
Carpet near the passenger door was damp, so possibly a little bit of intrusion near the fuse block on that side. Other threads indicate sometime flasher relay failure, or failure of the switch, which appears to be part of a module contains also the diff lock and antenna switches.
I'm not a highly skilled mechanical type, but can usually fix something if I know what to do. All suggestions appreciated. Thanks!
