Hazard as CDL switch - $2
Corsicana, TX
I bought a hazard switch at a wrecking yard today for $2.
It came from a 3rd generation mini.
Just in case anyone was confused like I was, you don't need a pigtail, just the switch.
As others have mentioned, it doesn't slide right in.
Less than 10 seconds with a dremel tool on the wiring harness plug in fixes that. I could also see using a hacksaw blade - also mentioned by others.
If you have never seen back there before, pull your dash apart first and locate the CDL plug in, and pull out your present hazard switch to just to see how it looks.
I went to the wrecking yard twice because I was unsure of myself. Had I prepared first by doing the above step first, I would have understood better what I was looking for.
Thanks MUD!
