Harsh Start Up Noise
Got an iPhone? Use Voice Memos app and capture a sound byte.
Best way to convey actual sound characteristics.
Good luck.
I can hear it allready, yup, thats a bad starter
X2 on the starter.
All I hear is the starter, then a real high idle. Check your ignition switch, it may be hanging longer than its supposed to, causing your starter to run a smoochems longer than required
I have no idea, but I know when I start the engine, and hold the key to start, and keep holding it there, I here that noise. Its the starter just spinning away. Also, when the starter goes, either it wont engage(no crank) or it gets stuck for a while in the engaged position(the zzzzsssshhheeee sound), which is what it sounds like to me. All in all, I wouldn't worry about it till it gets worse, I still have the original starter in my truck, its only 17 years old with 295k on it
