Hardtop ?
Columbia, SC
I have a 78 hardtop with no doors and I was wondering if the hardtop will fit on my 71 tub with no modifications. I have searched the FAQ and from the looks of those posts the only issues that I will come into is when I get doors on there. It seems that the later doors fitting on an earlier tub is the fittment issue, not the actual top. Am I assuming correctly?
Also once I get my top on there what options do I have for rear doors? I currently have the half doors. Would I have to change them to ambulance style doors or can I put a lift gate on a top that originaly had ambi doors?
Thanks for any help.
Jeremy
I put a 78 hard top on my 72 and was really pleased with how easy it was.
For the side doors, you'll need to change the door latches - just swap the ones from the 78 onto the 72. One important point! Roll cages that clear early door may not clear the wider late model doors.
For the rear ambulance doors, your upper hinges will come over with the new hardtop and for the lower hinges, you can drill and bolt through or use a threaded insert like a Riv-Nut or Nut-Sert. Would be easy enough to just drill some holes and use M6x10 or 15mm to hold on.
The early tire carrier is on the wrong side for ambulance doors but it's also easy to move a late model tire tubular carrier over - in this case it's a good idea to add some 1/8 plate bent to the radius of the inside of the quarter panel as a reinforcement - especially if you run a large tire.
The top will slide right on with one minor modification - you'll have to cut notches for the windshield wipers at the front of the top where it interfaces with the windshield.
Hey Jeremy!!
Here is what I learned when buying a hardtop for my '74 with the rear swing doors. I bought a top that I thought, and was told, would work. Believe it came from an early '70s Cruiser and had the hatch needed to work with the rear swing doors.
Come to find out that my Dec '74 FJ40 either had a newer windshield frame installed or that was right when Toyota switched over. Anyway, the location of the windshield wiper motor is key here!! Mine is at the bottom as where yours should be at the top. This make a difference on the channel that is attached to the fiberglass top and the holes in said channel that are used to attach the top to the windshield frame. These holes are in different locations, as are the cut outs for the upper mounted wiper motor and wiper arms.
In addition to that you'll have to decide whether to convert to ambulance doors or hatch. I've heard it can be done but it isn't really easy or cheap. I have seen some cool 'customs' done where people have cut the ambulance doors down to work with the rear swing doors or drop down tailgate. I'll look for some pics and email them.
At a minimum I'd trial fit the top and see what you have. You can try to find an older channel to use on your top but then you run into taking the old one off and attaching the other one to the fiberglass top without ruining the top. In your case I think your best bet would be to cut the channel to fit around the wipers and then cut your ambulance doors down.
BTW, Ron at Rocky Mountain Cruiser here in Colorado was able to get the older top I bought to work with my newer windshield frame...Doesn't seal perfectly but do they ever? You could always give him a call and get some first hand advice on what you are trying to do...
HTH
Jeff
Some pics...
Thanks for all the help guys. It looks like the cruiser I just got for parts has a lot more parts on it that I need than I originally thought. I did not think that the hardtop could be used.
What I think might be best is to take the whole windshield assembly from the 78 and put it on my 71. Hinges, glass the whole thing. Then fit the top on my tub and bolt it back to the original windshield frame. Then take the rear ambi doors that have rusted out on the bottom and fabricate some half ambi's out of them. Then I can either reskin the bottom 6" of my front doors and put them on there or find some one that might trade me for a set in better shape. How does that sound?
Jeremy
Corsair23, do you have any close up picks of how the doors were fabricated or maybe some advice on how I go about doing this?
Jeremy,
I emailed you the full size pics (1 MB each) but unfortunately I don't have any details re: how this was done. I don't even remember for sure where I got the pics but it may have been off an Ebay auction long ago. I sort of liked the idea and thought about doing something similar on my '76 before I sold it. Would make swapping out hard and soft tops on later year FJs a breeze having the rear doors like that.
You might try doing a search here and elsewhere on 1/2 rear doors etc. Who knows, it might have been a MUDR that did this!
Good luck on whatever you do and post up some pics when you get it done!!
Oh, and re: the windshield frame swap. Might not be a bad idea as you'd get the new wiper motor and if it ever goes you'll probably have better luck finding a '78 motor than a '71...Just another thought.
