Hardtop window seals
It is much easier to cut the seals. Check with the SOR web site,
they have many of the seals on special right now.
That said, many folks re-use the seals. You basically want to
push the windows out from the inside, with someone outside
to catch them as the seals pop. You may need to use a screw-
driver to start the process. I cracked one piece of glass trying
to save gasket, then found out that the gaskets were only
$15 each.
Another thing that might help is the rubber is easier to work with when warm, park the rig in the sun, use a blow dryer etc. When reinstalling soak the rubber in really hot water.
