I had my top hanging with rachet straps from my garage ceiling for a while.
Straps are fine for hanging but not really good for raising and lowering the top quickly by myself. I also wanted the top sitting on a frame instead of attached to hooks.
I needed the top as close to the ceiling as possible due to limited head room, so did not want a winch or pulleys between the top and ceiling.
I also wanted my winch mounted as low as possible so I don’t have to climb a ladder to raise and lower the top.
I had an old single bed frame that started me thinking. I attached two hand winches mounted on boards at each end of the bed frame. Ran the winch lines to pulleys attached to eyebolts in the ceiling and then back down to the other end of each board.
After I raised the top, I added two more eyebolts front and back and attached rachet straps there as well for an extra layer of safety.
As you can see, I need to work on my hardtop, so needed a better way to move it up and down. This system seems to work.
Passenger side:
Drivers side winch:
Rear safety strap:
Passenger side:
Drivers side winch:
Rear safety strap:
