Hardtop installation tips
Alpine, CA
When bolting the white fiberglass top on, start in the back corners and get the bolts seated. It's a lot easier to move the sides around to get the bolts in than it is the corners.
Plan on having someone around to push the sides in while you bolt.
If the holes aren't lining up, try sticking a drift pin or small phillips head in the next hole down and prying things around until the bolt goes in.
Be careful with the bolts that screw down into the back piece over the back doors. It's a weird angle and you could snap them off if you tighten to much.
Good luck!;)
also to add. As i just got my new hardtop from one of Orangefj45's friends a few days ago. When we were placing the hardtop on my cruiser his friend Ryan that was their to help pointed out that where the hardtop bows stick into the tub you can adjust how tight of a squeez you want the hardtop in there by rotating the adjusting screws. THis is located behind the seat of course.
good info source
