Hardtop gap - 75 FJ40
kcustom73
Stretched it...
Ottawa, ON, Canada
For the guys out there with their hardtop install, could someone please measure the exterior gap between the hardtop sides and the tub. I'm installing my sides onto an Aqualu tub and they tilt toward the inside of the cruiser, so I'm thinking the tub edge is a bit too high not letting the the sides sit properly. Any help would be great.
Anybody else???
There shouldn't be any gap. Mine sits right on the flat part of the tubs edge. DO you have the top's post screws backed out?
Sits flush on the 74 in my garage I believe, I'll check when I get home and update you.
All the Aqualu tubs I've installed have needed the top edge of the rear side 1/4s ground down to allow the top to seat properly......... I just modded one and will post pics tomorrow after returning to the shop........
Thanks for all the info guys. I've got pictures on my camera at home and will post them when I get a chance.
I've already cut the post off the front. The other thing I hadn't tought about when working on it the other day, is I don't have the gasket installed either.
Anybody know what the thickness of the gasket between the hartop sides and the tub?
Everything on this build is custom for me because of the 27" stretched Aqualu tub I got. So stretching the sides and hardtop means I've got to come up with my own custom gasket in most location.
There's a small gap on the sides because there has to be room for the thick rubber inverted "V" gasket. My original, stock top (and tub) is only really close in the very rear.
Am reviving this decade old thread. Now that we are in the smartphone Era, maybe somebody has some pictures of this process of mating hardtop to aqualu tub?
