I don't know of any on-line instructions.
I don't know if your PO (Previous Owner) maintained the top in good shape or not. Meaning if the bolts are rusty and frozen, if the seals are any good, etc.
Might be a good idea to simply disassemble the entire top the first time to inspect everything.
SOR has a rudimentary exploded parts diagram on this page:
http://www.sor.com/sor/cat108.tam?xax=3489&page.ctx=cat108.tam
The fiberglass top is held on to the sides and rear door or tailgate panel with bolts that are just inside the inner rim. And more bolts across the upper outside portion of the windshield. This is the first thing that needs to be taken off. It's pretty light, but two people should handle the top to prevent damage. The bolts might be rused, so be careful and apply penetrating oil if you need to and let it soak.
The rear doors or liftgate will need to be removed next. They are heavy. You'll need help. Then remove the cap that spans the two sides.
Now remove the spanner pieces that go from the sides over the doors to the windshield.
Then the sides can be unbolted from the body. There are also bolts holding a long pipe in place in the door pillar at the front of the body sides. If any of these bolts are frozen, use penetrating oil and be patient. These sides are heavy - get help.
The whole top weighs at least 250 lbs. Storage is a big awkward due to the shape of the sides. Plan ahead.
All the fasteners are metric. Invest in metric sockets and wrenches now if you don't have them. Many of these bolts also have a large Phillips pattern in the head, but I would use that for quick assembly and not for trying to break them loose.
If something is not coming loose, figure there's a fastener you haven't found.
Again, be patient. And be ready to clean and apply rustproofing paint and new seals and gaskets. If you aren't ready to invest in these, don't disassemble the entire top. Just take the top appart at the windshield and the body tub, plus remove the rear doors if you have the tall ambulance style doors. You'll need at least four people to lift the top off. A better way to do it is with a pulley or crane and sling it off. I've seen a photo of someone doing this with a heavy ATV hooked up to a pulley on a stout tree limb, down to the top. It gets lifted up and the FJ40 moved from under it.
Again, the top is very heavy - do not underestimate its weight. It ain't like removing an aluminum canopy from a pickup.
