In addition to the above you will run into issues with the windshield channel or whatever you call it.
This is the piece that is attached to the fiberglass top and sits in front of the windshield frame and gets bolted to it. On '74 and older (for the most part) the windshield wipers are at the top, '75 and newer they are at the bottom. The holes, notches, etc. in the channel are different. For you it will be a matter of notching the channel to clear the windshield wipers.
I went the opposite way sort of. I have a 12/74 with the older tub, older style doors, rear swing gates, etc. but my windshield frame has the wipers at the bottom. So...either it came that way 'cuz Toyota had it available on the late year build OR a PO swapped out the frame somewhere along the line.
Had to drills some holes for the bolts and use big washers. Doesn't seal real great (get a whistle above 40-45 mph), but otherwise it is ok.
You're plan is MUCH more ambitious! In my searches/talks I've heard it can be done (ambulance doors and reinforcing their attachment points may be the biggest challenge) but whether you will be happy with it in the end? Striker plate at the bottom of the rear channel for the doors should just be a couple holes and bolt it in.
Oh, and you can take a channel off an older top and put it on a newer top (to get the right holes/notches) but you risk ruining your fiberglass top doing so. IIRC the channel is riveted to the fiberglass top and that fiberglass is 30 years old or so. Could bolt it on with big washers but not sure how that would look.
Oh, and times 2 on the searching. Do an advanced search looking for key words in the threads not just the title
