Hard to get started?
Rapid City,SD
Hey guys, so i ve been having an issue since i moved back out to south dakota from california. Im not sure if its cold realated but it certainly seems so. Not everyday but almost every cold day ill hop in the cruiser and go to turn it over and nothing. just the click. All of my electronics work correctly, nothing out of the ordinary other then it not starting. but the thing is, it WILL start everytime. After several attempts it will turn over a little... The slow half turn over. then it ll click the next couple times . then one random time it will fire up like nothing was ever different. Im thinking the starter? any hindsite would be greatly appreciated.
thanks
josh
people like pictures
these trucks have an issue with starter contacts inside the starter solenoid. they are an item you can buy new from toyota, and that usually takes care of the problem.
However, first you check the battery and ALL the connections, at both ends of both cables. make sure they are all shiny clean and tight.
keep in mind that cold weather diminishes battery output, while at the same time, demanding more battery amps to crank and start the engine, so any weakness in the starting system will often show up in cold weather.
thats kind of what i was thinking when it started happening, with everything ive read here on mud!
x2 on starter contacts as probable cause. This web page describes how to replace them.
Thx for the picture. Definitely reminds me of SoDak.
What we do here and I am about to do on mine is add a Ford starter relay. as soon as I get mine installed, I'll get the pictures and the write up. For what I've been told is that it boost the starting system, we'll see.:hhmm:
Check this site, is basically the same principle for the Land Cruiser Tom's VW Solenoid Upgrade
thanks
josh
Howdy!
Hey, I have a cruiser like that to ( beside roof rack) :hillbilly:!
Check first the battery AMP and cable before to invest any money in parts? Battery Plus they do for free.
Good luck
:cheers:
