OK SO HERE'S WHATS HAPPENING. It will start fine anything below 60 degrees acells fine and even has a high idle. But anything above 60 degrees and a cold vehicle no high idle,won't hardly start. It takes several attempts to start vehicle and you have to feather the throttle. Can't acell until car is fully warmed up, touching the throttle will cause engine to fall on its face and die. After its warms up then it runs fine for the day unless you let it sit for about 6 hours then it repeats.
