Hard Start After Warm
tx
New 80 owner here. Picked up a 97 with 150k miles. Drove it about 100 miles so far. Seems when I first drive it each day it starts fine. Run errands, once its warm, it take double or triple the engine turn overs to get started. And it does not happen all the time.
Did a search and found several threads on this topic describing in similar issue. Seems like it could be a leaky injector. Now I know I should just start throwing parts at the issue but I also would like to create a baseline of servicing as I think new injectors would improve performance at a minimum and possibility fix the issue.
Can I just go to Autozone and pick up 6? Any particular brand I should get?
What is the best manual I should be working off of and where I can pick it up at?
Thank You
Not sure if I'd jump straight to injectors, but if you want to do them I'd just get yours cleaned. I used Witch Hunter.
You should use the Toyota Factory Service manual.
You can download it here:
For Sale: - 40, 50, 60, and 80 series FSM for a hell of a price.
They're kind of a pain to get at and you'll need some other gaskets and seals as well. This thread details how to take off the intake and fix another common issue while you're in there:
P0401 Defeated - with pics
Warm start issues are often caused by an old and worn distributor cap and rotor. A new Toyota cap and rotor are cheap and easy to install and good preventative maintenance (along with spark plugs and wires).
Its not slow cranking. Turns over just fine. Battery is fine. It just takes more revolutions when warm.
I thought swapping out the injectors would be an easy job. Will read some more.
I was thinking the same thing. Create a baseline. Plugs, wires, cap/rotor would be cheaper way. They should be replaced anyways.
Yeah start here. Those are easy. Plus, most of the injector reports I've seen posted here indicate the injectors are fine.
Autozone quality is fine right? or do you folks recommend Toyota oem?
Toyota OEM only. Find one of the several vendors on this forum for a significant discount, fast shipping, free advice and know you are getting the correct parts. Autozone parts are a no no!
