Hard Brake Lines
Clemson, SC
I have a 68 fj40... I am installing an 85 fj60 booster and master and installing a 78 front disk brake axle. I am replacing all of the brake lines...rubber and hard...due to corrosion. And plan on doing a RDB conversion with the monte carlo calipers...Now no one stocks the hard lines so it looks like I'm gonna have to get them from Napa. What is the thread size from the Master cylinder down to the calipers so I can buy the right lines. I know I will have to probably cut and reflare the rear ones cause I believe the monte carlo calipers have a standard and not metric thread size. Thanks for your help guys.
Chuck
10mmx1.0 thread at the master....
What hoses are you going to use, Toyota metric? If so, then it will be the same fitting size.
Good luck!
-Steve
