H55F transmission shifter help
Kuwait
I’ve been tackling this problem for the past hour with no progress, I’m stuck on getting the shifter collar out to remove the shifter anybody has any tips? This thing is pretty hard to depress and turn at the same time, it’s counter clockwise right?? I also had another question about the transmission, when pulling the engine out I noticed the whole transmission is angled and was wondering if that’s normal…
The 60 series bell housing rotates the trans 5~6 degrees
Thanks for the transmission info.. as useful as that tool looks I’m not in a position where I can get it easily, located in the gcc, ordering that part will take over a month to get here.
It's a factory Toyota item. I assumed that Toyota's presence in the Middle east was very good
Got it out.. Ended up having to cut the top of the collar with a cutoff wheel and get the spring out, that spring simply refused to compress and had plastic pieces wedged in which made it a headache.
