H55F Shifters
Fayetteville, North Carolina
Will the 60 series shifter (photo #1) fit in place of the stock 40 series shifter (photo #2)
Yes it will.
What I believe is different is the angles. Because the 60 series is wider it angles towards the driver's seat. I have test fitted a 60 series shift cane from a four speed in my 68 with 74 bucket seats. It is right against the driver's seat when in reverse. Five speed might not angle to the left as much. I know it's been done but may need to bent the cane up a little. Has to be worse with a 60 series top cover.
The shifter for my H55 which was installed in my 40 rested on the drivers seat in 2nd. It had to be heated and bent forward to clear.
I have purchased a H55F with a 40 top plate. So the shifter is located forward towards the firewall. It currently has the long spindly looking shifter. The 60 series shifter reminds me of the shifter I had on a NV4500 in my 2nd 40. If a 60 series shifter will fit without being modified I will swap it in.
What year 40 are you installing it in? 79+ are easiest with 83+ requiring almost nothing except driveshafts lengths changed. When I try a 60 series cane in 40 it was with 73-78 bucket seats and transmission cover from the same range. That was with a H42 with 40 series top cover. With a five speed being taller it might clear the seat better. But the can is bend towards the driver's seat. by you picture looking at the two slots that locate it in the transmission you tell the angle of the cane. Because my H55F can out of a RHD BJ42 besides changing the input shaft I need to straighten a bend main part of the shaft. For some reason the RHD have a bend in the 40 series cane.
shifters yes. Boots are not in the photos of my purchase so my assumption is that they will not be included. Are you saying that even though I found the h55f for a 40 that I will need to modify the transmission access panel.
images
Crap.
I will add applying heat to the base of the cane to bend it could effect the epoxy used to put the two piece of the cane together.
Mine is loose but I am accustomed to it and having the extra travel gear more than makes up for any inconvenience. It also adds a bit of a theft deterrent when I remove it, the shifter is very short and would make it hard to swap gears.
Oops not sure what's left of mind brain was thinking. Should have been I would NOT be applying heat. My first 60 at a wrecking I grabbed some 60 series was either a 81 or 82. The shift cane was loose and pulled right off. I realized there was no real mechanical connection. Figure the two pieces was a way to reduce vibration. Something the 40 series does have. Just wonder why it was until the FJ62 that the transfer shifter got it. The transfer is the one with the biggest problem. Not sure how I would feel about driving with a cane that would come off. I'm sure it would be like everything else and just adapt. Steering and brakes would have to be fixed.
