fyi.. for those having wiring issues...
Gary at Innovative Wiring makes custom wiring adapters.
He made my high beam adapter that I use with the depo headlights
Male 9005 to female H1 (59 series)
gary@innovativewiring.com
What bulbs do you have? My hid kit I had in the depos looked nothing like that. I wasn't flashed at all in the 6ish month period I had them in.
I bet you get flashed all the time with a cutoff like that.
I was running the Prolumen HIDs and the bulbs that came with them. This is the kit:
Next Thursday....a nice FX-R Bi-Xenon HID projector retrofit in deop's is in the works![]()
Someone, not mentioning any names, cost me $200![]()
Mirage said:Question -
1. Do I need the Slee harness for the depot lights?
2. will they fit in a 1997 LX450 without modification?
3. With Gary's adapters do I need to change or add any relays?
thanks so much
Question -
Just an update on the parts numbers LS6480 has been sub'ed out with LS6247.Picked up a set of the Depot headlights on eBay. The wiring is an H1/H4 style bulb. I couldn't find a thread on Mud that explained how to wire these bulbs up so here it is:
Search results for Toyota depo landcruiser in Car & Truck Parts & Accessories
The lens is clear glass not plastic and build quality is not OEM by any means but well made.
Another thread on these headlights
H1 Ground and positive lead. The positive is the center lead. If you look at the plug that goes directly on the bulb you can see one leg is the outer portion and you can trace it to the terminal.
H4 pinout looking at the rear of the bulb with the middle pin on top:
Left - Gnd
Right - High Beam
Top - Low Beam
Napa part numbers:
H1 female plug = LS6480
H4 female plug = LS6479
H1 bulb 55watt = BP1255/H1
H4 bulb 55/60 watt = BP1260/H4
Female 9005/9006 plug and pins - need to find a source. Black with 2 ribs inside is high beams, grey with one rib on the inside is the low beams.
Also It might just be easier to go with Innovative Wiring - Toyota Products
With H1 H4, in low beam only the H4 low beam is on.
In high beam, H4 low beam is off and H4 and H1 high beam is on.
With 9005 and 9006 one is high beam and the other is low beam. The adaptor harness above does not address this difference. Another relay would be needed to make it work properly with H4 and H1 bulbs.
I don't think you'd really gain much with the highs on the H4 instead of the lows on the H4, especially given how little (relatively) most people use high beams to begin with.
I was looking closely at the picture on the website and it looks like there is a wire for the high and low beam leads on the H4's. I am wondering if they have jumpered the high beam lead to H1 power lead?....
I ordered one so I will let everyone know when it arrives.
(JDM had H3C fogs in the same spot).
I do live in a deer country, so I tend to use the high beams more often than some folks. So every extra lumen counts.![]()
How well did the fogs work there? Seems they'd be too high.
I also live in deer country, so know what you mean. Just couldn't justify a few extra lumens for 5x the price. Of course I wasn't looking at your monster H1 bulbs either, which I wouldn't feel comfortable running with the OEM harness.
Depends on what you are looking for.
You are correct that you do not gain the functionality of the dual purpose H4 bulbs, in effect the high beam on the H4 bulbs are ignored and you get only the lows. But Toyota doesn't turn off the low beams anyway, and high beams (even with stock setup, let alone H4/H1) are extremely bright.
