SOLD H151F 5spd swap kit - Port Coquitlam, BC, Canada. $5500 CDN plus shipping.
Status
Not open for further replies.
Port Coquitlam, BC
Got a full 5spd swap kit that I was going to put into my HDJ81, but I've decided to focus more on my Troopy and need to free up some cash. See parts list below.
PARTS MISSING FROM LIST: clutch lines, driveshafts and trans cross member, this is 99% of everything you need to swap your auto HDJ81 into a freight train pulling 5 speed manual.
It took me a few months with orders from Amayama, Megazip and Partsouq to get all the parts in. They've been sitting on my shelf for 6 months now, and they need to go. Located in Port Coquitlam, BC. Will put on a pallet or crate and ship, at buyers pre-paid expense. Can also arrange delivery with a small deposit upfront and within a reasonable distance.
Major Parts:
H151F Trans and bell housing
Brand new 275mm flywheel and pressure plate, used clutch.
Used 300mm clutch and pressure plate - can have flywheel machined to accept 300mm parts
RHD Shifter console with leather boots
Clutch pedal assembly
Clutch master and slave
Rear main seal
Pilot bearing
Throwout bearing
Comes with all parts listed below, other than the ones mentioned above. Parts list taken from @gnarlynick2072 build thread. You may need to pick up some odds and ends, but this is 99 of what you need.
Quantity NeededDescriptionPart NumberVendor
2​
block dowels90250-08054Partsouq
2​
transfer case dowels90250-12002partsouq
9​
bell housing to trans bolts91611-61045partsouq
1​
bell housing to trans shorter bolt91611-61035partsouq
10​
bell housing to block bolts91619-61245partsouq
1​
bell housing cover platepartsouq
1​
main engine seal90311-95008partsouq
1​
input bearing90363-15017partsouq
1​
flywheel13405-17020partsouq
2​
flywheel pins90250-10192partsouq
8​
flywheel bolts90105-12169partsouq
1​
clutch cover31210-60162partsouq
8​
clutch cover bolts90119-10205partsouq
1​
clutch disc31250-60401partsouq
1​
slave cylinder31470-60180partsouq
2​
slave cylinder bolts91611-B0825partsouq
1​
fork pivot31236-35030partsouq
1​
clutch ford31204-36110partsouq
1​
throw out bearing31230-60181partsouq
1​
fork boot31126-60050partsouq
1​
shifter knob33504-20120-C0partsouq
1​
front drive shaftpartsouq
1​
rear drive shaftpartsouq
1​
manual trans cross memberpartsouq
1​
manual tran mount12371-61050partsouq
1​
clutch pedal pin90249-08018partsouq
1​
clutch pedal bushing90386-08033partsouq
1​
clutch pedal locking pin90468-16142partsouq
2​
pedal pads31321-14020partsouq
1​
master cylinder31410-60372partsouq
1​
master cylinder gasket31415-60020partsouq
2​
master cylinder nuts90179-08038partsouq
Brake pedal47101-60210
breather tube clamps96132-41000megazip
tcase tierod
3636060330​
megazip
SHAFT, CLUTCH PEDALpart souq
SHAFT, CLUTCH PEDALmegazip
NUT(FOR CLUTCH PEDAL STOPPER)megazip
BOLT(FOR CLUTCH PEDAL STOPPER)megazip
WASHER SPRINGpartsouq
CLIPpartsouq
NUTmegazip
CUSHION, NO.1(FOR CLUTCH PEDAL)partsouq
BUSH(FOR CLUTCH PEDAL)partsouq
COLLAR, CLUTCH PEDAL SHAFTmegazip
BUSH(FOR CLUTCH MASTER CYLINDER PUSH ROD CLEVIS)partsouq
PIN, W/HOLE(FOR CLUTCH MASTER CYLINDER PUSH ROD CLEVIS)partsouq
SPRING(FOR CLUTCH PEDAL)partsouq
BOLT W/WASHER91651B0814partsouq
I was told it was working and running perfectly fine.
Status
