good day cruiserheads,
after 200kms of off road driving, i noticed that my 80's tranny sounds wierd like when you let the truck crawl at 1st gear with your foot of the clutch and off the accelerator pedal you'll hear a " grrr....grrr....grrr... " sound but when you step at the accelerator pedal to put some speed, it sounds normal. This happens on 1st 2nd and 3rd gears. specially on 2nd and 3rd gear where you will experience a slight hesitation like on and off jerking untill the truck picks up speed it returns to normal.
The tranny has new clutch disc, pressure plate, release bearing and newly refeced flywheel. It uses a sae 90-140 gear oil.
Is this Tranny rebuildable? does it have any adjustments?
thanks...
thanks...
