Guages not working
Well not all of them, the amperage guage works. The temp, oil pressure, and gas don't though. This is on a 71 FJ40.
I checked the fuses, they are ok. Checked the wiring in the cluster and it's ok. Any ideas?
On a 71 w/stock motor the oil pressure sender is on the driver side of the block low and to the back.
Did your gauges simply stop working? Or have they not worked since you bought it or...?
May want to search as well, I think this topic came up a couple months ago.
Matt
Sorry for the lack of details. Let me explain a bit:
My buddy (74K5 on here) got the FJ40 this past fall did a bit of work to it and it's been sitting since.
He said all the guages and the speedo worked just last week when he took it out to drive. Now just the amperage gauge works.
I checked the fuses, they are good. I will pull out the multimeter tonight and see if I can figure it out.
I'm thinking there is a common power wire that may came loose or somthing.
I believe there is a common power wire for the three gauges. The amp gauge is of course separate, with wires running directly to the alt and battery.
A likely culprit is the contacts on the fuse block. I've had this happen to me and seen a number of others mention it.
Matt
Yup. Those three gauges are on a common connector, that can get unplugged. Follow the yellow wire from the 5 amp fuse.
